cj's mopar
Hello ,
I want get some opinion on the cam I am using currently and would I have been better off going with more upper Rpm range cam because of the motor specs.
Here is the build
400 bb Mopar block
440 crank
Ross pistons 1.730 deck height.
383 eagle rod
Stealth heads with better valve job and be hive springs .
Crane golds from the 90's
Smith bros push rods 5/16 ball and cup
Hughes 226 228 cam older hyd roller grind.
510 520 lift
Brand new six pack set up for induction
The engine is very snappy and has clean plugs .
Down low torque is kinda week imo.
Seems like this motor wants to RPM.
It is in a 69 super bee post car.
Hemi 4 speed
391 sure grip 83/4
I have attached best performance run on no prep no burn out run.
Cam is to mild for me but I don't want to strap with to much cam.
What does the guru's say?
Here is the build
400 bb Mopar block
440 crank
383 eagle rod
510 520 lift
Hemi 4 speed
391 sure grip 83/4
