Bad ignition switch or wiring problem? Autometer fuel and Painless Wiring
canblue
5:30 AM
Ontario, Canada
I am trying to shoot an old problem with my Autometer fuel gauge. When the key is in acc postion, the gauge reads 1/4. When I turn the key to start/run, the gauge reads empty. I am not a mechanic or skilled electrical person. I posted here as I think it is a problem with the ignition switch. Hoping for some direction on solving this problem. The gauge pegs when the sending wire is grounded. The ignition system is not stock, Crane HI-6 CD. Electrical is by Painless for Mopar.
Not really sure where to start.
Sounds like a wiring problem. When you turn that key on that circuit is not powered. Need a 12 volt key on circuit. My 2 cents.
Definitely a wiring problem.
In ACC there must be a crossed wire which is adding some resistance to the fuel gauge circuit - thus giving you a partial read on the tank.
Please elaborate on 'gauge pegs' - is this FULL or EMPTY pegging, and is it instantaneous, or gradual movement?
Thanks for the reply. Need to make a repair plan for next spring. The weather is not cooperating for drive way repairs. Will collect all the information that I can. The non OEM wiring adds to part of my confusion as most of the information is on the OEM harnesses.
Immediate peg past full.
Many of the aftermarket wiring harnesses have a problem in this area. Mopar ignition switch has 7 terminals if I remember right, and new harness has less wires. Trying to connect the last terminals can be a swearing and head scratching few moments
