Another LED Light Bulb Question
RR Fan Dan
If it ain’t broke, fix it till it is.
12:45 AM
Virginia Chesapeake Bay
After researching the forums I am going to get my bulbs from here
The correct incandescent bulb for my 74RR instrument cluster is 158. This LED bulb says 168. My question is this the right bulb and how many do I need?
I used the cool whites in my dash but kept the factory blue diffusers in pace.
Here's what it looks like...
Another question as to the turn signals. I replaced the rear tail section lights with LED's and everything works fine. When I put LED in the front turn signals they don't work. I am assuming I need LED flashers. For the 1974 RR what is the correct LED flashers that I need and where are the locations? I found one in the fuse box, where is the other one and which is which (turn signal and hazards)?
No flashers in the fuse block, that's the horn relay/key buzzer. Turn signal flasher is clipped to the ashtray frame, the 4-way flasher is clipped to the brake pedal support. Can’t run the original thermal flashers with all LEDs, need an electronic version, not load dependent.
Hey @71Beeper that looks awesome! I like that the light seems to spread evenly. I saw in another post that you got them from superbrightleds. Are they the ba9s style?
I found these on their site, but they are stated as non-dimmable, are these the ones you are using?
BA9s LED Bulb - 5 SMD LED Tower - BA9s Bulb
If so, I might have to look elsewhere, as I want to be able to dim them to ensure they are not too bright.
Yes, those are the ones I bought.
Depending on the color you use, they should not be too bright at all to have to dim them.
Don't forget you can buy them with higher or lower output lumens.
For 1971 the bulb base is the round one not the flat pigtail style.
So I bought the above awhile back and am just now getting around to the install. I ordered 2 off of Amazon in the same order and I am just now noticing one of them came with a ground wire and the other is identical to the one pictured on the Amazon order without a ground wire. The car is at the shop and they are going to put these in. Will the one with the ground wire work, and if so does it need to be grounded?
