DynaBro
And there was oil under the driver side hood springs for some reason. And here's the engine stamping.
Cold or after warmed up. 80 doesn't bother me. My 383 Bee fires and starts at 85psi and at temp and driving 60 or so. My Hemi cold is 90.Close to 80
First, check the oil pressure with a good mechanical gauge.Close to 80
Well my car arrived yesterday and I am becoming a little bit disappointed in it's condition.
I guess it depends on that main seal leak. That cardboard is what collected overnight.Buyer's remorse?
I hope not.
1) you don't need to prime the oil. You didn't let it sit for a long time.
2) I have no suggestions for an oil pump gasket. Do you know that is the source of your oil leak?
It's difficult to determine the condition of things in pictures, but keep an eye on that lower radiator hose.
It's the model you have always wanted and yours is nicely optioned. It's an old car. Enjoy the journey!I guess it depends on that main seal leak. That cardboard is what collected overnight.
The engine in my Bee was rebuilt for $350 in 1977 ! I've done nothing to it since, other than a timing chain and gears and valve seals !!!Sure but your Bee is like beyond perfect
Oh I know this is not the original bock I just took photos of those numbers while I was down there so see what it actually was. Seems to be period and model correct.Not to be pedantic, but those numbers and letters are cast with the block. They are not stampings.
Maybe you're looking for the partial VIN stamped on the flat pad on the passenger side of the block just above the oil pan? I thought you had already checked.
I'm of the same opinion after inspecting this morning. The dripping is on the oil pan side of the K member right on the corner where the oil pan curves. Nothing else could end up there and there's nothing I see leaking from above.As previously mentioned, I would suspect the seals inside the oil pump. $11.00 for a gasket kit, cheap and easy. If you drive in cold weather, I personally would swap out the high pressure spring with a standard one while the pump is out. It's not common, but it is possible to shear an intermediate shaft or balloon an oil filter.
Milodon 21591 Milodon Oil Pump Gaskets | Summit Racing
Edit
I think Milodon fixed the issue, but if you order the gasket set above, check the paper gasket for all the holes cut out. If you read the reviews, some of them weren't cut properly and blocked the supply passage. Also it might not come with the relief valve gasket.
The engine builder is long lost. Best I can do is eyeball the spring once I get the pump removed. Any tips on what I should be looking for to get some more info on my situation? Or maybe just buy a certain new spring now and install it regardless? The manual is sparse on oil pump removal stuff but has a lot about measuring tolerances I don't think is the issue. Per the oil pressure issue, yes driving it is always at 80 or near, and the needle is buried at points. I know you said you aren't worried when it's that high. My temp is usually like 180ish so I'm correlating that as good despite the high oil pressure. I don't have a gauge on hand, perhaps one of my neighbors does.First, check the oil pressure with a good mechanical gauge.
Check with the engine builder to see if he changed the pressure relief spring in the oil pump or installed a high volume oil pump (maybe a HVHP).
80 psi wouldn't bother me on startup with cold, heavyweight oil.
I was thinking doing a full clutch adjustment would be a good plan considering how little the previous owner seems to have done. I think their plan was just "store indoors, don't drive often." I had not considered the boot but think mine is worn in adequately and likely not the issue.I put a new boot on my shifter, now I have the same problem as you, it likes to pop out of first when sitting at a light. Hoping the boot loosens up over time and the problem fixes itself.
