Whats everyone working on?
No major projects until winter, but I did recently fix the temp gauge on the GTX by replacing the aftermarket sender with an NOS one. I also figured out an issue with the tach in my ‘58 Apache, the signal wire had a pushed connector at the distributor plug.
Almost finished with this '34 Indian and extending the shed
I will be doing sheet metal replacement on the 68 R/T over Christmas, rr will be bolted together and driven, it’s only original paint once!
70 gtx
This week I got the cowl cover off and the replacement fitted.
Then I drilled about 200 MORE spot welds and removed the front framerails and radiator shroud.
Monday I will weld the replacement rails in. I got a front "clip" with good rails and shroud attached but the rear cross member was swiss cheese. We tacked a piece of 2x2 between the rails before removing it so we could maintain the spacing. I also welded an XV Motorsports front rail frame stiffener under the radiator to stiffen the front end of the rails.
Nice work, I will be doing my 68 Charger firewall over Christmas!
Hopefully, I'll get to work on my 66 Belvedere 2dr sedan this winter. A 440 has been on the stand for years but have a 4 speed and lots of other stuff for it....
Getting ready to bend new rocker panels for my Hornet. The stock ones rusted out because the car had full width factory stainless steel rocker panel trim that allowed dirt and moisture to get trapped behind them.
Tom
got it blasted waiting on compressor for over a week but should be resolved today, staring on patching a few small holes tehn installing new trunk pan and tail panel.
Just to get it going --- What is everone working on?
Man!! Everyone looks real busy out there!! Good to see! Im multitasking with everything. My 70 GTX. 20+ years off and on.69 Charger R/T 440 in the machine shop. Been sitting for 20+ years I’m 64 and trying to get **** done!! lol… life’s good!!
My first Mopar after being a Chevy guy for many years, then converting to VWs for the last 10 years (the blue Westy in the background is a lot of fun). The body, undercarriage, and frame were pretty much done by the PO but that's where they stopped. Luckily, the headliner and carpet is new and the interior in very good shape. Numbers matching 383 / 727 / 3.23 car with 64k original miles. It runs great and is very fun to drive. If one knows how to shift, it's fast and really comes on hard above 2500 rpms. Since it's a numbers matching car, I was a little hesitant to do mods like headers, cam, GV OD unit, etc. and maybe a 3.91" crank stoker in the same block but I'm warming up to it.
I need to fix little things like power steering valve leak, trans shift shaft seal leak, get the windshield wipers working, stuff like that. But at least now all the gauges and lights are working except the speedo and the vast majority of parts that came with the car I've installed. Now if I can only figure out the whole "above the door" headliner retainer weatherstripping and how that long, angled metal piece attaches and how the rubber fits into it, I'll be a happier man.
To all on this forum, thank you for your continued input and advice, so far. It has been immensely helpful.
Later,
Mikey
