4 hours in.. figure 2 more to go and another foot forecast tonight. 21" of soaking wet crap so far.
View attachment 1766150View attachment 1766151
Grade 12?When I built cars, nothing ever went back together stock. Every bolt in the car were these. I had every size and length known to God. I still have far too many.
These have an alloy in them that make them by far more practical. These are grade 8 and 10.Grade 12?
R.C.'s baby video!![]()
Is that you…….
If you're just looking for a small base, try this: https://www.amazon.ca/Brake-Replace...3012532&sprefix=brake+drum+7+,aps,137&sr=8-28The bottom is drilled and tapped for two 1/4 inch bolts to mount it to a base.
Ready to mount and pull wire. I'll be looking for a base. I may go to auto zone and buy the smallest brake rotor they have. We'll see, I've got nothing but time.View attachment 1766233
The problem is, the smaller the diameter, the heavier it needs to be. It's going to be about 25 inches tall. I'm thinking air filter, top only with paper air filter for a shade. Open bottom for light to shine down. I don't think a harmonic balancer is even going to be heavy enough. I could do it out of some mahogany, but I'm thinking all metal. I'll probably go antiquing, but that can be dangerous. I have a habit of buying now for later. I'll end up giving it all away. Thank you for thinking of me!!!!!.. UlliIf you're just looking for a small base, try this: https://www.amazon.ca/Brake-Replace...3012532&sprefix=brake+drum+7+,aps,137&sr=8-28
Look on craigslist for an old livingroom pole lamp in the free section, it'll have a weighted base.The problem is, the smaller the diameter, the heavier it needs to be. It's going to be about 25 inches tall. I'm thinking air filter, top only with paper air filter for a shade. Open bottom for light to shine down. I don't think a harmonic balancer is even going to be heavy enough. I could do it out of some mahogany, but I'm thinking all metal. I'll probably go antiquing, but that can be dangerous. I have a habit of buying now for later. I'll end up giving it all away. Thank you for thinking of me!!!!!.. Ulli
Poverty hubcap.Look on craigslist for an old livingroom pole lamp in the free section, it'll have a weighted base.![]()
