Road Grabber
- 11:55 AM
- Apr 14, 2020
- Sarasota Florida/NY State
Since I purchased Trickflow heads I have seen posts about MLS head gaskets working "better" than the Felpro 1009 gaskets. I did call Trickflow ahead of time before engine work and they said the 1009 gasket should work fine. Trickflow even lists the 1009 in the parts needed for assembly.
Now I have read the MLS gaskets are better when using the aluminum heads next to the cast iron block and but the block needs to be smooth for the MLS gaskets to seal properly.
What I don't know is how would I have checked the surface to see if it was smooth enough to use the MLS gaskets? Would you only use the MLS gaskets if the block was decked?
This is a 1968 440 block. Never decked bored .030.
If it was your block, would it be worth removing the heads to swap with MLS Cometic gaskets?
Felpro makes MLS gaskets but not for the 440. They claim their Permatorque gaskets are more forgiving with rougher block surfaces.
