Chrysler 8 3/4 Axle bearing and Seal R&R...A How To
Thanks for the excellent write up. One thing I do is put duct tape around seal surface of axle to protect it. Don’t ask me how I know!
Don't recall ever messing up an axle seal surface but have always been careful with axle removal etc.....
I do, just a tiny nick. Even though I was careful. Had to tig that spot and turn it in a lathe. What a pain!
TIG welding the seal's contact area creates the real possibility of axle failure, due to taking the temper out of the shaft (reducing its local overall hardness), making the shaft prone to reduced torque capability (twist).....it was likely that the original seal surface was produced by centerless grinding after hardening.........just my opinion.....
BOB RENTON
BOB RENTON
Not if heat is limited and the weld is very tiny.
To the contrary.....localized heating, due to TIG welding, can cause internal stress point(s) which may lead to failure. What type of filler metal was used....was it compatible with the parent metal (percentage of carbon)....if cold rolled, was the area preheated b4 applying TIG. You would have been better off using a "speedy sleeve" for repairs to the damaged seal surface......just my opinion......
BOB RENTON
I am working on y OE dana for my 69 Coronet R/T. can I buy new correct tapered flanges for adjusting the bearings? (OE style tapered bearings) or does anyone have any OE bearing flanges for sale?
BCA A7RK and A7LK. Comes with bearing, races , lock ring, gaskets, outer seal, and retainer plates. RK comes with new adjuster plate and adjuster ring. Search for them on Fleabay. Note inner tube seal is smaller OD than on an 8-3/4 because of way thicker tubes on a Dana. Attached is parts list and notes I made from my 70 Dana/powerlok rebuild last summer:
I need bearing adjuster/ flange, for the passenger side, drivers' side is a solid flange. both if possible.
Post on fbbo WTB and /or troll fleabay. Dana plates same as 8-3/4, so in theory you could pirate from a junk yard 8-3/4, but you’d have to pull whole axle and cut the bearings off to get to the plates. Or just buy A7-RK and A7-LK, they come with new plates and the adjuster. You’ll need new bearings and seals anyway since you have to destroy your bearings to remove your plates. Read my post above!
