64 Dodge 4 Speed Pedals - Install Issues
Charlie Brown
2:20 PM
Vars, Ontario, Canada
I have a 4 speed pedal assembly from a 65 (supposedly) B Body ready to install into my 64 Polara. The connecting pedals bracket seems upside down (bent down and not up) and interferes with the steering column support bracket. Is the column support bracket from an automatic different from a manual shift?
From searches on this site it seems that the column bracket installs between the plate and the brake pedal housing and not on top - either way, I have an issue. Thoughts please.
Charlie
I have a 65 set up collecting dust from my build, I ended end buy a recon set from another member that was a good deal.
I am east of Syracuse NY
Charlie
Hi Dan, I do go your way from time to time and if I can't fix up what I have, I'll let you know. Thanks.
In both the 62 and 64 FSMs and this piece turns down in the pics, no distinction between V8 or 6, 3 or 4 speed.
Mine turns up and fits fine in my 62.
No idea why some turn down.
I asked in a few threads, no one seems to know why some turn up, others down:
62, 63, 64, 65 Clutch Pedal Assembly, differences?
My 65 assembly when removed.
I scratched my head on this issue, and came up with this simple fix. I cut the down curved edge off and flipped the edge facing up and welded it - looks almost factory now.
My 63 is turn down , wonder if reason is the dash , 64 and 65 is about the same.
I’d like to see how it’s bolted on? I would think the angle part would not allow it to fit right.
I just wanted to add to this thread for anyone down the future. The info I could find is that the 62-63 flange turns down and 64 turns up. Why? Who knows it looks like it is irrelevant. Fast forward to today. I pulled the pedals out of my donor 63 for my 64. Didnt think the flange would matter, but it actually hit. How Charlie flipped it is probably the better option, but I just notched mine the fit on to the bracketry. Dammit my pictures are to big to download, so this reply is pointless!!
