Charlie Brown
- 7:00 AM
- May 23, 2021
- Vars, Ontario, Canada
I've been planning this conversion for 2 years now. I purchased the complete kit from SST Transmissions. For those who are interested, the complete kit was $5700 USD shipped. I've asked for a lot of advice and guidance on this forum which has helped me a lot, and it's probably not the last of it either - I've already run into two glitches. Anyhow, here's my story ----
Started the conversion last week. Taking out the front seat and because the car is a convertible, dropping the top makes interior access a ton easier.
Photo of car before I started.
Next the dash comes out for easier access to change the pedals
Pedal assembly removed
I had a glitch with the factory 4 speed pedal assembly - I thought the pedals I got with the car were from a 65 B Body, but they turned out to be from a 63 - there is a slight difference in the steering column bracket attachment - see this link to see how I solved this item - 64 Dodge 4 Speed Pedals - Install Issues
As per kit instructions, I removed factory clutch rod pin on the clutch pedal and installed supplied adjustable rod with new pin. I ground off the weld and the factory pin was knocked out.
After mocking up the new pedal assembly and hydraulic slave cylinder in the car, issue number two is apparent. Things don't line up and the connecting rod is to short.
I sent a note to SST today with a few pics and will be on the phone with them tomorrow to try and resolve this issue. More to come!
