340runner
- 12:37 PM
- Sep 2, 2024
- Naperville, Illinois
So, with my new advent of the desire to fit a big block mopar, and realizing that it would solve some of my gearing issues with torque, I'm looking at a pretty barebones setup but that'll be stout from a 440
Also, i guess the best way to get stuff done effectively is to plan ahead, want to be around 500-600NA hp and similar torque with ability to add another 100-125 from bottle
Looking at a motorhome 440, from 1975-77
What heads come on the motorhome 440s? I've heard they are weird, and can't be worked through as much due to having extra water jacket passages
Crank since they don't come with steel in that yr is going to be a sourced OEM steel crank
Are the stock rods capable of 550NA hp rods, maybe with a 100 shot in the future? Upgraded rod bolts of course, not looking for much rpm, 6-6.5k max
Aftermarket pistons unsure of the CR needed but probably going to be around 10.5-11.0
Is this realistic on good tune and 93 + octane booster, octanium? Also will hyperectuic or however you spell it hold to the power?
Cam is going to be hydraulic flat, going to consult with hughes when the time comes for something that fits to my build.
Heads is either going to be the stock motorhome heads with some work done to them if it'll stay to my desired power figures, or 906 heads or speedmaster(i know it's Chinese but read above budget)
Intake is probably going to either be a eddy variety, whatever is better suited or the speedmaster, cause if I get the heads I'm getting the top end power pack
Carb, do you think a 750cfm holley double pumper is small, big or just right for this build?
Headers is going to be something pretty budget
Is this realistic for my power level I want? What would you say this combo makes honestly? What more could you do to push it to where I want to be?
I honestly just don't want to do all the work to build it, drop the coin, just to have something that's slower than I had before
