FOUND Wanted: Carter 2Bbl and electronic distributor for late 70s/early 80s 318.
493 Mike
2:53 AM
White Cloud, MI
Feedback: +9 / =0 / -0
I am converting a 318 Lean Burn system. Need carb and distributor. I can rebuild if needed.
Thams.
Mike I have a carb that I bought for the charger,had to many vac lines. PM me if interested, brand new ran about 2 hours.
If your interested.
I have a set from an 86-ish 5th Ave.
Gonna be a while to dig it out, though.
Wait, are you looking for lean burn carb and dist, or non-LB?
You should delete that for him. :BangHead:
Been telling members not to do that for a very long time now......but if they don't listen maybe they will when the scammers jump on them?
Thams.
Help, what do you mean by lean burn 2 barrel? It's lean because it has limited gasoline flow being a small 2 barrrel? Thanks
