Screwed and Glued in Torque Boxes?
65PlymSatellite
12:37 AM
Inland Empire, CA USA
Hey Everyone,
Just wondering if anyone has ever screwed and glued in Torque boxes? Was just looking at some build motivation, and I Came across this '65 Belvedere with torque boxes that dont appear to be welded in.
Anyone done this before? Can't imagine this was a good idea. Or maybe I'm just uninformed?
The PT Cruiser, Chevy HHR and some others use bonded on, not welded, quarter panels. Viper and some others have structural items bonded to their frames. Depends on what they used for bonding material. Try it and see or put some heat to it, melt the adhesive, clean off the residue from the areas, weld it. Me, I'd melt and weld. The old cars had nowhere near the structural strength, torsional rigidity, that later model stuff has.
If it was mine, I would be welding them in.
Panel adhesive holds the steel scoop on the hood of my 65 but, is it strong enough to hold against the torque that the engine may develop or high-speed cornering could input into the chassis? I'm discounting the sheet metal screws!
1. The screws are in case/when the glue fails, you don't have to stop the car and run back and to pick up the torque boxes in the road before another driver runs over them.
2. Be sure you use the right glue when you install your PVC subframe connectors
3. But to save weight don't forget any the glue on the outside the bonded joint increases strength very little.
4. And the most important reason heard here often, "what can it hurt?"
I not sure its a horrible idea. Panel bond is pretty tough stuff. If its not right up against an exhaust pipe, it will mostly hold until the cows come home.
If your not going to properly weld them in then why waste the time.
I'm told by my body shop supply sales rep that when properly applied, the panel bond is as strong as welding. He had no comment on Bovine livestock.
For me though, I choose to weld.
I’m open to the newer technologies over welding when it makes life easier and the risk is low, but on something that looks structural and has easy access for welding then welding it is for me.
Panel Bonding Adhesive
Product Description
3M™ Panel Bonding Adhesive is intended for use in outer body, non-
structural panel attachment applications, including applications where
panels are used in conjunction with welding and/or riveting. Industry
professionals appreciate the performance benefits that 3M™ Panel
Bonding Adhesive provides, including the continuous bond, load
distribution, ease of use that drives more consistent results, corrosion
protection, and excellent adhesion to a wide variety of substrates.
3M™ Panel Bonding Adhesive is a two-part epoxy adhesive which
provides a long open-time or work-time but can be rapidly cured with
heat once the panel has been positioned and clamped into its proper
position (see: Rate of Strength Buildup at Various Temperatures chart
below). 3M™ Panel Bonding Adhesive also contains 10 mil glass beads
to help users control bond line thickness and to prevent excessive
squeeze out.
There are of course many factors and variables that can affect an
individual repair, so the technician and repair facility need to evaluate
each specific application and repair process, including relevant vehicle,
part and OEM guidelines, and determine what is appropriate for that
repair.
Features • 3M™ Epoxy Technology
• Corrosion Inhibiting
• Heat Cure onDemand
• Bonds Steel, Aluminum, SMC, FRP
• Contains Glass Beads to Control Bond Line Thickness
Product Uses
panels are attached in conjunction with welding and/or riveting.
vehicle, part and OEM guidelines, and determine what is appropriate
for that repair. Examples of where Panel Bonding Adhesive may be
used in conjunction with other traditional joining methods in a repair
scenario, subject to OEM recommendations, can include door skins,
roof skins, quarter panels and box sides.
This product is not intended to be used for structural parts, such as
pillars, rockers, strut/shock towers, frame rails, or frame members
unless specifically recommended by the vehicle manufacturer and used
in the manner specified in the OEM repair manual and procedures. If
doubt exists as to whether a particular component is structural, consider
it structural.
3M
https://multimedia.3m.com
PDF
Panel Bonding Adhesive - 08115 - Stronger security is required
