Park lights and dash lights turn on when pressing brake pedal
Wcotner96
9:19 PM
keizer Oregon
Been working on my 70 RR and cleaned up the dash and got new bulbs in everywhere, headlight switch is new and all lights come on as supposed to,
Brake lights do not work when lights on/pedal pressed
Lights off/pedal pushed all park lights turn on
Gotta be a wire crossed possibly or bad ground? Any help would be greatly appreciated
I think you’ve got wires crossed. I suggest you pull off the driver’s kick panel. There’s a plug there that included the tail/brake lights. Start looking for melted wires/terminals there and cross check wires with a meter vs the wiring diagram
You make no mention of the turn signals or 4 way emergency flashers working? Do they work?
Hey, so right rear signals work, right rear hazards work, I unplugged the tail light harness and it does the same thing. So issue may be in the dash I imagine just not sure where to start
What? So the left side does not work? That is such a simple system.
all lights work when turning on with the switch, left signals do not work nor flash with hazard switch, right side turn signals work as do hazards on right. Brake lights do not work at all. Tail lights stay same brightness when braking
Take all the bulbs for the front and rear park and turn signals. Fix one at a time. My bets you have one rear socket messed up and possibly a bad turn signal switch.
What wire colors are arriving to the brake pedal switch prongs?
They should be pink and white… no matter which where. Pink from fuse box (“batt” throught a 20 amps fuse, so allways hot), white to TS.
Well, just an update got it figured out, my uncle for some reason ran a wire from the brake switch to the dimmer switch,, not sure why but pulled it out and got rid of it and lights work perfectly. Thanks everyone
Not a smart uncle.
At least it’s fixed! Maybe he was trying to warn oncoming drivers?!
