Another LED Light Bulb Question
Bulbs grow in the garden.
Yes, you will need to attach the ground wire, at least I needed to on my Charger.
I’m currently powering up my dash after a resto and Led bulb install this week.
Interesting issue I had which might help someone. Emergency flashers worked great. I used red LED’s for the tail lights.
But turn signals did not work. Since I installed a new turn signal switch that’s where I did my troubleshooting. Spent quite a bit of time looking over the pin out on the TS plug.
Issue was polarity ! The E flashers are on a separate circuit using dual filament tail light bulbs.
I changed the polarity on the turn signal flasher and all worked correctly.
So E flasher and TS had different polarity on each flasher module.
I bought the flashers(2) that are in the pic. You just change the cap to change polarity.
Thanks. The shop put in the LED flasher at the brake pedal for the 4 ways, but missed the turn signal flasher at the ashtray, so the stock flasher was left there. They installed LEDs-all the way around except the front turn signal, because when they put those in they didn’t flash. With incandescent bulbs in the front turn signals and LEDs everywhere else everything works. I’m hoping installing the second LED flasher fixes the problem and I can run LED bulbs in the front turn signals.
Just keep in mind that the second flasher will need a ground and possibly polarity changed.
How do you change the polarity? Switch the wires at the flasher terminal block?
Yes, but probably your wire plug won’t allow you to do that due to the shape of the plug.
That’s why the flasher I included in the picture of my post allows you to put the cap on the flasher to change polarity.
The cap has internal wiring.
Research that flasher and find a picture of the underside of the cap.
I would assume if it has a ground wire, it needs to be grounded for it work correctly. If its too late to return it and get what you ordered, I’d use the ground wire version for the four-ways, fairly easy to get at (ground) compared to the turn signal flasher.
Thanks, would I need to reverse polarity on just one with the ground or both?
Original wires to turn signals would get reversed. Then test to see if they flasher. In my car the emergency flashers was fine in normal configuration. I had to reverse my TS flasher using that cap.
@BDnFL Can you tell me where I can get that same cap? Both flashers installed by the shop today and the front turn signals don’t flash. They put the one without the ground at the ashtray, so it would be the turn signal flasher, so that is the one I need the cap for.
Just have them swap the two Packard connectors in the plug if it’s a polarity issue, its easy, don’t need to buy anything. Never had this issue with these flashers, never had to reverse connect them
The shop is also getting frustrated with these, and based on what @BDnFL said it may be a PITA, so I want to make it easy on them, or do it myself. I would prefer to buy the caps. Anybody have a link for the correct reverse polarity cap for the flasher I showed above?
I bought mine off eBay.
If you google the model number in the picture many choices pop up. Flasher module 90652.
View attachment 1819754View attachment 1819755View attachment 1819756View attachment 1819757
Buy the flasher and cap as a set. Use the pic previously shown.
72 Roadrunner is correct in changing pins in the plug.
But I figured if he’s paying labor to a shop, and reversing pins in the plug doesn’t help he now has change the wires back to troubleshoot the real issue. This way he can do it himself.
