Manual trans shift rods
old guys rule
2:27 AM
Jacksonville, FL
I need custom shift rods made for my 833 od. No idea where to look. Any Ideas?
Why do they have to be custom?
When I first dropped the engine and transmission in I discovered the transmission was not built for an a or b body asI thought. The shifter mounts were in the wrong spot so I got creative with a torch and tin snips to expedite the project ( dumb I know) later on I discovered that the rods needed creative adjustment due to cross frame interference. Got the torch out for adjustments and made them work however shifting is less than acceptable. It is an a body OD unit in a b body. Don't know where to take it to resolve the problem. Any suggestions?
Why not just put in a OD truck transmission in it. The only change that needs to be done it to use a different yoke because of the spline count on the output shaft.
Mopars at the Rock (Rockingham NC) is next Saturday April 5th. Is about 5-1/2 hours away from you and I’ll have one available for $200. I’ve opened it up and it looks like new inside.
