Fan for her shower. This is her bronze that hangs in the same bathroom...Women's bathroom fart fan repair, eh?
Just out of curiosity- what does Dennys call this? Flying phallus special?^^^ After that effort we had a lunch at Dennys just down the road.
It is definitely the customer's own bust - it was done a few years ago, so things have moved 'south'Just out of curiosity- what does Dennys call this? Flying phallus special?
And was she the model for the bronze bust?
   The weeds are free of charge.Nice tan.It is definitely the customer's own bust - it was done a few years ago, so things have moved 'south'
That Dennys dish is the "Superbird sandwich" - my go-to.The weeds are free of charge.
@kiwigtx this reminds me of a mess I just sorted out in my master bath. When I did the remodel in 2017/18, I installed a heated tile floor control next to a 2 gang box with switches for the fan, which I had relocated to this spot and a shower light. The fan is humidity controlled so I normally leave it off and it will run when the shower is on, or the humidity is high. The problem was that when I turned the fan on by the switch (fart fan) the heated floor turned off. I've known it wasn't right, but since the fan ran in humidity mode, I've been ignoring it. Well, this winter has been catching up on details and small unfinished projects like this so I tore into it. I could not understand why I did what I did. It was totally bufooned but wasn't that hard to straighten out. My explanation/excuse was that I had a stroke while working on this room and that little mess was put together just a few days after that. I never quit working on it to 'take time to recover' as was recommended to me. My recovery was getting up and doing my normal routine every day for as long as I could. I really should have waited on doing electrical projects. And sheetrock. And tile...The bathroom monkeys couldn't figure out this simple 4-gang switch..... they somehow fumbled the heated towel rail connections....
Push-button switches with illumination LED's. I even had the LED's working correctly for the two-way circuits. Lucky they didn't have to try that.![]()
You must have taken the supply for the heated floor from the switched side of the fan switch - needs to come from the Live side of the fan switch.I installed a heated tile floor control next to a 2 gang box with switches for the fan, which I had relocated to this spot and a shower light. The fan is humidity controlled so I normally leave it off and it will run when the shower is on, or the humidity is high. The problem was that when I turned the fan on by the switch (fart fan) the heated floor turned off.
Yeah, and I had a wire between the 2 switches that I have no idea why it was there as well as a couple other issues. Like i said - bufooned. I'm certainly no electrician but can normally handle the basics. All is good now.You must have taken the supply for the heated floor from the switched side of the fan switch - needs to come from the Live side of the fan switch.
There are a few things going on there - the heated floor will be thermostatically controlled, and the humidity switch is also in play.
Sounds like you need the Goodson crew to reform and build you a new pathway to the building....Started a new flooring project 1 mile from the Darlington racetrack in Darlington SC. I had to literally drive through a swamp to reach the building. The floor plan layout is going to be a pain in the azzzz
Life-size.![]()
Update!
I built that back when I was 8. Have had it on display ever since. Then 2 weeks ago the cleaning lady decides to dump it off of the shelf and broke off a bunch of parts and not tell me about it.So now i am restoring it.
