65-440
- 12:02 PM
- Dec 2, 2009
- virginia beach, va
Just installed a new tach from charger specialties in my 68 coronet (standard dash), with the ignition off the needle slowly sweeps backwards and settles in around 6500rpm..key on it jumps to zero. Needle is erratic with engine running, bouncing around pretty good. Called them and one of the guys is saying it's the magnet from the dash speaker causing interference. Makes sense seeing as the needle is pretty much pointing in that direction with ignition off. Has anyone else experienced this and if so what is the fix? I've tried shielding it with some metal plate but no luck at all.
