Exhaust U-Bolt Clamp Torque Spec
boboh1
9:37 PM
Claremont,CA
What would be a good torque spec be to tighten the U-Bolt clamps when putting together an exhaust system? Thanks.
What size are they? 5/16 or 3/8? You can use general torque spec by thread size.
Ot just tighten the hell out of it.
No need for torque specs here, tighten until the mufflers and pipes don't move. If you have an exhaust leak you tighten some more.
I agree.
When possible I prefer stepped band clamps but you need to get good quality clamps.
With band clamps you can take it apart and reassemble without cutting up the muffler or pipes.
I've always used the "just enough, and if it ain't enough, a liitle more" method on exhaust.
I like to tighten them up just enough to keep them from slipping. I like to run straights and have to throw mufflers on for the yearly state inspection so my exhaust system needs to be 'serviceable' and that means it needs to be able to pull it apart. But finally Texas doesn't safety inspect cars anymore and don't have to worry about doing that now. Band clamps is a better alternative to regular muffler clamps and better yet, tack weld it a couple of spots to make sure nothing slips etc. Just put the tacks where you can easily get to them if and when you need to take it apart. Also, I used to experiment with different mufflers so it was imperative that my system came apart easily.
tighten it up until it strips or breaks, then back off 1/2 turn.................
:drinks:
