1967 Dodge Charger Seat Belts
Charger Too
8:16 AM
Illinois
Where does this seat belt holder attached to? Is it
for the front or rear seats? I need to know the exact location. Thanks!
Front seat outside position, the belt has a winder that retracts it into that holder.
So it bolts on the rail right inside the door, and it does not bolt on the seat, correct? Thanks!
It bolts to the floor...bolt goes thru it, and the seatbelt...into the floor...front seat...outside of driver, and passenger seating.
You can see the holder like yours on the passenger side in this picture.
On the outside. So you can buckle the seatbelt and then pull the end to snug it up.
Interesting that it has 67 seat covers and interior. Someone went to some work apparently.
Yes even the dash frame is 67. I'm going with, it's a 67.
Ayuh... you're right, it's a 67! I had it in a folder with 66 pic's on the PC... should have looked first before sticking my foot in my mouth :lol:
Of course, my 67 will have a 66 console, because I like the 66 console better. It looks cooler and it's a lot sturdier (Composite) verses the 67 (ABS) console.
Not that it matters, but this is one from my 67
View attachment 1836872 View attachment 1836873
RemCharger scabbed a 66 out one of the cars back about 1993. Keep saying I might sell his 67 console.
I have used ABS material to reinforce/ repair them. You could probably put 100 lbs on the back part.
Like the picture.
So now you have a car with 4 buckets, 5 ashtrays and 3 cigarette lighters?
Probably no one smokes in the car!
Actually replacing the lighter on the dash with a hood release from a 66. The ashtrays are mainly for storage of USB plugs for the other lighters.
