Charger Too
Where does this seat belt holder attached to?  Is it
	 for the front or rear seats?  I need to know the exact location.  Thanks!
			So it bolts on the rail right inside the door, and it does not bolt on the seat, correct? Thanks!Front seat outside position, the belt has a winder that retracts it into that holder.
It bolts to the floor...bolt goes thru it, and the seatbelt...into the floor...front seat...outside of driver, and passenger seating.So it bolts on the rail right inside the door, and it does not bolt on the seat, correct? Thanks!
Your plastic holder is a different style than mine as I compare your photo to mine above. Do you agree?
Where is the cut end of the seat belt material at when it is fastened around a person? Next to your body or showing on the outside? Thanks
Interesting that it has 67 seat covers and interior. Someone went to some work apparently.That pic is from a 66... I just posted it to illustrate it's attachment point location
Yes even the dash frame is 67. I'm going with, it's a 67.Interesting that it has 67 seat covers and interior. Someone went to some work apparently.
Ayuh... you're right, it's a 67! I had it in a folder with 66 pic's on the PC... should have looked first before sticking my foot in my mouthYes even the dash frame is 67. I'm going with, it's a 67.
that makes 2 of usOf course, my 67 will have a 66 console, because I like the 66 console better. It looks cooler and it's a lot sturdier (Composite) verses the 67 (ABS) console.
View attachment 1836872 View attachment 1836873
RemCharger scabbed a 66 out one of the cars back about 1993. Keep saying I might sell his 67 console.Ayuh... you're right, it's a 67! I had it in a folder with 66 pic's on the PC... should have looked first before sticking my foot in my mouth
Not that it matters, but this is one from my 67
Interesting choice of wordsRemCharger scabbed a 66
I actually like the 67 console. I replaced the rear "grill" with one that has the light and lighter. Think it is a big improvement.that makes 2 of us![]()
Recycled might better apply
Recycled might better apply.
So now you have a car with 4 buckets, 5 ashtrays and 3 cigarette lighters?I actually like the 67 console. I replaced the rear "grill" with one that has the light and lighter. Think it is a big improvement.
Actually replacing the lighter on the dash with a hood release from a 66. The ashtrays are mainly for storage of USB plugs for the other lighters.So now you have a car with 4 buckets, 5 ashtrays and 3 cigarette lighters?
Probably no one smokes in the car!
