Dibbons
- 5:35 PM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
I don't believe either one is the factory style for this 1972 340 factory intake manifold, but both will physically bolt on. The older style (painted white) is a heavy metal (cast iron) and a little pitted here and there, but cleaned up best I could. The other is a lighter metal (aluminum?) and brand new in the box. The new one has an odd cut-out which could be either a machined boss for some kind of switch or maybe it is some kind of bleeder passage for the thermostat. Don't know. The old one has a lip on the end of the longer snout for the hose and the newer one has a smooth, shorter, straight snout.
Anyhow, which one would you choose? Of course, the upper radiator hose may end up to be the deciding factor. Thank you.
