- 1:54 PM
- Jul 17, 2008
- South Jersey USA
Agree on all of this except the first part which is a bit confusing...
put a straw in your mouth and suck (pcv).......
ok, yes, the PCV has a one-way check valve yes?
if you plug the other end (breather), you can no longer suck
Not sure what you mean here. If you have a breather, the breather end is open, not closed, correct?
One thing to note here, in keeping with the OP's issue - my car has a carb and he's running EFI. Both can benefit from a PCV valve, but I imagine that each have different requirements for a breather cap vs no breather cap on the opposite side since carb is an open system and EFI is a closed system. Am I correct on that?
if you have a breather opposite of the pcv valve, air enters the engine thru the breather; which is what you want...... no breather, no air; without a breather, the pcv valve is useless
