Engine Fire, Not Charging
win32exe
4:05 AM
Worcester, MA 01606, USA
Hey Team, A friend of mine who has a 67 satellite had a small engine fire and i replaced a few damaged items like plug wires, fuel hoses, plastic accelerator pump arm etc, we got the car running safely again but now it doesn't charge, i have a 67 Belvedere but mine has an internal regulator, single wire alternator so i cant use mine to aid in troubleshooting.
i need to chase voltages to see where the dead wires are, i am betting the Alt and regulator are still good but some of the wiring is a little crisp.
Pic 2 i see on the back of the alt. one of the fld connections is hooked up and the other fld isn't and that connector that isn't is too wide for a regular spade connector, the alt wasn't near the fire, but is that connection ok like that?
Pic 1 shows the ballast and what i think is the voltage regulator, how do i test the wiring for correct voltages.
car runs but doesn't charge, any help is appreciated
Henry
Based on purely what I can see, I'd recommend getting a new engine harness.
The wiring condition does not look safe to me.
Classic Industries offers them (but their website is pretty crappy so you have to look carefully)
I would recommend considering the ones with electronic voltage regulator and maybe the Chyrsler electronic ignition plugs.
Here is the stock one:
https://www.classicindustries.com/product/1967/plymouth/satellite/parts/mp900137.html
This is really cheap insurance.
Thank you, that looks good, i will run it by him, that one says Stock Style Breaker Points, i didnt see any points in the distro, its a pickup coil, will that harness still work?
Thanks again
Henry
Thanks again
Henry
No you'd need the modified version that I mentioned.
I didn't notice the corner of the orange box in the one picture.
I like the electronic voltage regulator much better with the new harness it's really easy.
i didn't see the modified version, just BB and SB, do they sell it? do you have a link for the electronic VR? pretty sure he would like to go with a better solution.
Thanks again
Henry
https://www.classicindustries.com/product/1967/plymouth/satellite/parts/mp900138.html
This one has the connector for the ignition but I don't see the connector for the electronic voltage regulator in the picture?
They are available from RockAuto though.
that looks even better but its not in stock, do you know of anyone else who might have that same harness?
what about the first piece of advice i got about grounding the second fld contact on the alternator, i do see talk around that point but not sure his engine fire could have undone that, maybe his car never charged since he swapped the alternator? its a pretty sweet car, he doesn't drive it much.
Thank you Don
Thank you Don
Put an ohm meter on that field terminal between the metal and the case.
It needs to be connected to the case with the old style points voltage regulator.
It does look like it might be insulated from the case (or open), if so then it will not charge.
Or just put a test jumper to a good ground and see if it charges.
ohhh, the points are in the VR? and he has a points style VR? the black box next to the wiper motor? my setup is different
Hey team, i installed a new wiring harness, the new harness came with one FLD connection for the alternator, it fired right up but still isn't charging, i grounded the second FLD connection and it still doesn't charge, do i need to jump the 2 FLD connections? my 67 belvedere has both FLD connections wired.
Don, what does the Ohm meter between the second FLD and ground tell me? how do i determine if needs to be grounded (which i already tried) or excited?
Thank you
Henry
With a old point style regulator one terminal gets excitation voltage and the other gets grounded.
The newer solid state regulator runs 2 wires and neither terminal on the alternator is grounded.
See if you have voltage on either terminal of the voltage regulator when running. You can also jump across the regulator temporarily and see if it charges.
Either the regulator is bad or the alternator is if you grounded 1 terminal and it didn't change.
is there any visual way to tell which voltage regulator is installed, points vs electronic?
do i leave the regulator connections in place while i temporarily jump across the connections? or disconnect the leads and jump the two leads?
what will happen if i excite the second FLD connector and shouldn't have? will it break anything?
I'm learning a lot with this
Thank you Don
The black voltage regulator in this picture is definitely a points style unit:
This is what a solid state regulator looks like:
You can jump accross the existing regulator you've shown with a wire.
All the regulator does is close/open a set of points within.
I don't see a problem if you accidentally power both field wires at the alternator, it just wont charge.
this is making sense now, my belvedere has the solid state regulator and has both FLD excited, his satellite has the points style and one FLD should be grounded.
i will ground 1 FLD, jump the VR with the connections in place and see if it charges, does that sound proper?
the fire was in the VR area, maybe the heat took its toll on it
Thx, ill post my results
Henry
ok, here are my results, vehicle running, 12.25.volts from post to post at the battery, 11.5 volts at the battery terminal at the voltage regulator, 3.5 volts at the FLD side of the voltage regulator and at the FLD terminal of the alternator. i grounded the second FLD terminal of the alternator and used a jumper wire to jump across the voltage regulator, the meter went up .25 volt, not much.
should the FLD voltage be 12-14 volts normally? just pulsed? is it a bad VR?
the fact that a jump across the VR didn't change anything so it must be the alternator?
are there any further "in car" tests i can perform? like put temporary battery voltage right to the FLD on the alternator?
i could pull the alternator and take to the auto store for testing, if that is the next step.
Thanks again!!
Henry
If you had 12V on one field wire and grounded the other and it didn't charge, then the alternator is NG.
Did you test the "battery" wire on the alternator while you did this?
Maybe it's just not getting back to the battery.
i didn't put 12 volts to FLD at the alternator, i just measured it at 3.5 volts.
the battery wire at the alternator was 11.5 ish, the same as the batt wire at the VR
