WHICH DISTRIBUTOR TO USE
MIKESPOLARA
6:00 PM
CALIF
My 426 wedge clone has the over the counter Mopar distributer 3690201 without vac advance and the timing is locked out. I prefer to run a vac advance unit and not one with the timing locked. What dist/brand would you recommend. I'd like to have it plug in and keep my electronic box with vac advance.
Might want to consider a FireCore distributor. Very well built with easily adjustable curves. I've been quite pleased with the one I have on my car that replaced the one that came with the Mopar Electronic ignition conversion kit. My experience was that the Mopar unit developed some play / slop after a few years of use.
I have also used several Firecore distributors, and have no complaints.
I looked up the Firecore. Looks good. Says direct plug in. What is involved with the mechanical advance curving procedure?
They have slots you adjust with a phillips screwdriver like originals. Mallory keys work with them as well.
I used a Summit dist, which came with adjustable vac adv. If you intend on connecting the VA to manifold vacuum [ a veeeery smart move ], you should have an adj VA unit. Whatever brand, the cenrti curve will likely need dialling in for your combo.
Another option if you want an original style is to buy a rebuilt one from @HALIFAXHOPS.
That Firecore looks like what I want. Now just to decide if I want to bother. Someone wanted to buy my Mopar 3692021 tach drive dist a long time ago on here. Maybe I need to look into selling it.
