- 7:41 AM
- Jul 17, 2008
- South Jersey USA
I have a holley 770 and a points dizzy you can use
I honestly just don't know yet. I haven't been able to diagnose the issue, so I don't really know what to fix.So your saying there may not be a quick fix for the FAST problem?
Trust me, that thought crossed my mind, but converting back to a non-FI system is not straight forward. The fuel system pumps at 43 PSI, the locked distributor and ignition system all are different, and carefully integrated into my wiring harness. My car might look like RoadKill fodder if I try to switch...I have a holley 770 and a points dizzy you can use![]()
Well, then both of us are knee deep in working on our cars to get them ready!YES I plan to join! I better get my arse in gear too, unfortunately working full time has been getting in the way... lol
Besides getting the new third member installed I am planning on:
1. Flush/drain coolant then new upper/lower hoses, thermostat housing and thermostat (180 degree)
2. Replace valve cover gaskets
3. Tune-up: points, condenser, rotor, cap & spark plugs
4. Oil/filter change - greas job
5. Rotate tires
6. Check exhaust manifold nuts and bolts for small leak
7. ...
looking less likely for me, sorryAs I stated above, I will be starting a PM group chat with all the RSVPs this weekend.
I do not have a confirmation from you, so if you plan to join us please let me know. Current tour attendees:
@joel snyder
@Skytrooper
@Armyvet25
@Don Frelier
@Nxcoupe (Plan is to dyno my car at his place)
Please let me know ASAP if you plan to join us and are not on the above list.
On another note: I continue to have issues with my Road Runner. Quite frankly, I am concerned now. I went through the ignition system expecting (hoping) plugs and distributor cleanup would address the issues. It did not. After some discussion with F.A.S.T. support, the injectors could be problematic. Pulling them is not particularly easy and I don't know how fast I can get a new set. But I am working diligently on them...
I hope to get this issue resolved and will bust my arse to get the car fixed. If I cannot, then my backup plan is to drive my beater daily driver Corvette (and I have no doubt I will take a lot of crap for driving a Chebby...). NOT what I want to do, but the best I can do if I can't get the Road Runner fixed in time.
I understand. Sometimes things don't come together as fast we hope.looking less likely for me, sorry
Hopefully I can source them quickly enough, get them in, and that they are indeed the issue.In this case, it is stupid. Me! Even if this does not turn out to be the issue, not running a fuel filter with fuel injection is a really bad idea. Not sure how I missed putting the filter back in, but it is what it is....hopefully, that solves your problem......more often than not, it's something stupid and/or simple
Shortly after I had the first overhaul done on the C15 Cat in my Peterbilt, an oil sample showed fuel in the oil. The shop did a pressure test, and replaced five defective injectors under warranty. I paid for the sixth out of pocket to play it safe while the truck was down. Nearly $700 installed. I was careful about filter changes before that event, but I became paranoid afterwards.In this case, it is stupid. Me! Even if this does not turn out to be the issue, not running a fuel filter with fuel injection is a really bad idea. Not sure how I missed putting the filter back in, but it is what it is....
Well mine both run perfectly.Update: I have the injectors on order - they should arrive on May 23rd.
So @Don Frelier promised me that this was the issues, so if not, I get to borrow one of his cars!!!
Anyway, I got them on.Correct. Actual AFR value doesn't change at all.Afr reading doesn't change at all?
On the MSD it reads 35 when you power up and don't have the engine running.
Did you try raising the setpoint to like 15 or higher and watch the duty cycle on the injectors?
From what I understand, the O2 sensor is a Bosch LSU4 type, reading wide band air/fuel ratios from 9:1 to 16:1. It's designed for closed-loop applications. So yes, there are differences in O2 sensors, and I think I have the correct replacements, but they are not FAST branded.@HawkRod
Could there be a difference
in O2 censors, between Closed & Open loop systems ?
just spit-balling, or does a O2 sensor in the F.A.S.T. EFI not care
location of the censors, not on the bottom of the pipe
needs to be up the side or on top, so excessive moisture doesn't kill it
good luck
