Blue Brick
Our patient:
1977 400 with Lean Burn conversion to a 5 pin, single terminal ballast, with a Mopar distributor that has vacuum advance.
The conversion was completed by the previous owner.
Battery has 12 volts.
With the control module unplugged; the positive and negative posts on the coil have the same voltage, 11 something.
With a control module plugged in, the positive terminal is 5.46 I think, and the negative is 1.4.
There is no spark from the coil during cranking, only a little faint spark towards the end of the cranking cycle via the inline spark tester and the coil wire.
The unhooked pickup coil measures 282 ohms.
Tools:
Performance Tool Digital Automotive Mult.imeter
Old fashioned test light
High Energy Ignition Tester
New parts:
Cap, Rotor, Coil, and plug wires (replaced after the problem occurred)
This is a father-son project and it's not a daily driver. The car was difficult to start. Once it was started it would intermittently shut off. This happened in the driveway. We drove it to the gas station and the car remained running while I was putting a couple dollars worth of gas in it. After we left the gas station, it suddenly shut off. I was unable to restart it (drained the battery). I pushed it to a side road and began trying to attempt to restart it via a jump start. Starting fluid did Not cause it to bark whatsoever. After a little while it did restart like a champion, but shut after I traveled the distance of about 400 feet.
Any suggestions, recommendations, or feedback would be most welcome.
Before posting, I did use the search feature to try and find similar posts with the same symptoms.
I am familiar with the Dura spark system and I'm leaning on the control module the possible cause.
Tools:
New parts:
