340runner
- 10:23 AM
- Sep 2, 2024
- Naperville, Illinois
Thank you very much my man
Which model year is your runner?If only someone would loan me $7,900 haha (obviously joking).
Yeah its great but out of my price range right now. I know i would be into a 440 more for the same performance, but at least with a 440 the money is spread out and not lump sum (makes it hurt less). Wish I had the money lol
Its a 71, not like i care about the date on the block anyways. No roadrunner came with a max wedge anyways to my knowledgeWhich model year is your runner?
Why not pick up another 340 block if your not content with doing a 360. 340s are out there. You could do a stroker and save a bunch of time and money swapping over parts off your current 340 and keep down time minimal. I am a big block guy, but also have a 71 340 4 speed car. Your goals are doable with a small block and if your thinking somehow that painting stealth heads on a bb are going to make it a sleeper, going fast with a 340 b body is even more of a sleeper. Your car has had a 340 in it this long, if you want a bb car it will come, your young!!!.
I bracket raced a friends 85 buick regal a couple weekends ago since our car wasnt ready. The buick has a 377 sbc and 3.73 and is a upper 11 second car. It has iron heads and a hydraulic roller cam, nothing special...but fun. It's a good example of having fun with a small block..even if its not a mopar.
11.5 e.t. can be done w 500hp and some good 60' times w a stock stroke 340. Steel crank sb stroker kits I've seen for $2500, depending on whose kit it us. Driving on the street, running a bigger engine will make it more drivable. Probably worth it, if you can swing it.Well, its around me 1000 at LEAST for a block that will still need machined, which i checked and is around 1000$ all in, compared to a supposedly machined 440 block, will check, a forged crank, good rods, and l2295fs for 1000$ also I think this 450 will sit for a bit of time until I can afford because its on a member only classified and not fb marketplace
Then do you think I can achieve my goals stock stroke 340, or will I need a stroker kit? At my planned goals for power and rpm I need a forged crank, so its 3250 + tax and shipping for a stroker kit
Working up, I need new cam and lifters either way with either engine
Then on heads, I have speedmasters right now which need went through on the small block
I dont think the money saved with accessories and small stuff will be offset Because 1. Already got a 383 that had good accessory brackets and stuff, but just had a rusted out cylinder wall because it sat for years without spark plugs in the cylinders, and mice took over
2. 440source is cheap for what accessory stuff i dont have
Then we get to the part where people are saying that a small block especially long armed is going to self combust over 600hp, which i will be well over after the laughing gas, but my machine shop says they have 440s that live over 750hp with a girdle easy.
Well can 500hp be done with a stock stroke NA 340? 11.5 e.t. is the starting point, juice for even more fun where tech don't matter. yes I'm slightly unhinged11.5 e.t. can be done w 500hp and some good 60' times w a stock stroke 340. Steel crank sb stroker kits I've seen for $2500, depending on whose kit it us. Driving on the street, strokers would make it more drivable. Probably worth it, if you can swing it. You may want to comsider intalling a temporay "runner" sb to drop in while you go through your present 340. The car will be down less than trying to get everything lined up for a bb swap. Little things take a lot of time.
Sure. Building a 500hp 340 will be pretty rowdy, it will help keep you unhinged.Well can 500hp be done with a stock stroke NA 340? 11.5 e.t. is the starting point, juice for even more fun where tech don't matter. yes I'm slightly unhinged
Well, i run 4.56s on a welded diff. On the street. On bias ply slicks even on special occasion. I take corners slow, pray for NO rain, hope i don't pop a tire, and its fun.Sure. Building a 500hp 340 will be pretty rowdy, it will help keep you unhinged.![]()
Probably near 500.Also what will the torque be out of a 500hp 340?
Yeah, I guess my views have been altered for the worse, at first I really thought my car was the stuff, then I started driving around some kind of quick street cars from my friends Then the addiction grew, and now I want MOREProbably near 500.
I do get the bb idea. We have a 65 dart that has a really small engine compartment, it has a 440. I am a bb guy all day long. But I wouldn't rule out a sb if your budget is tight. You are quite lucky to have a 340 for starters. Just seems someone had no clue on the build. No compression and a poor cam choice. We have a 340 4 speed as well, but its in a duster.
Quite frankly pistons and a cam swap would be a great start. Do that, gap the rings for NOS and hit kit...and it is what it is. Having goals is fine, but don't let it ruin the fun. There is always a faster car out there. Enjoy it. Knowing you made it faster then the last guy.Yeah, I guess my views have been altered for the worse, at first I really thought my car was the stuff, then I started driving around some kind of quick street cars from my friends Then the addiction grew, and now I want MORE
I dont know, I guess my thoughts is why with the big block is the same thing some guy said to me about the 383. For anything you can do to a 383, you can do to a 440 and have more. I guess the same applies to a 340, just to a lesser extent. The one thing my previous owner did right though was put in a 8 quart oil pan and a high volume oil pump, I dont know why that cam card says power band maxes out at 6400, it has never nosed over on me past that
Yeah, certainly so. Just there's always the nervousness i guess that this is the numbers original block for whatever that's worth, that i REALLY don't wanna window itQuite frankly pistons and a cam swap would be a great start. Do that, gap the rings for NOS and hit kit...and it is what it is. Having goals is fine, but don't let it ruin the fun. There is always a faster car out there. Enjoy it. Knowing you made it faster then the last guy.
Okay, what has me wanting a 440 powered car? Well, I had a original post, one of my first where I asked what can I expect out of my car, and a lot of people told me GO BIG BLOCK, as my car is heavy even with a small block. My top end and water pump housing and radiator are all aluminum, and im still at 3800 with me in it. Well, I got that 383 in the other thread, and a lot of people said go 440, as i could do everything to a 383 to a 440 and get more for the same price. Well I was kinda adamant on sticking with what I had, up until that block turned out to be terrible. Terrible pitting. I don't have a 440 machined block with a good rotating assembly lined up, but I'm talking to a guy right now who's old, and is selling all of his stuff so I can get a short block for a 1000(machined 76 440 block, forged crank, resized rods with good bolts, and trw domes). I have a 4 speed and a mcleod street extreme clutch and flywheel already, so from small to big i just need the bellhousing, which I was always thinking of going to a SFI one anyways at the rpm I turn, I dont want to have my legs turn into ground beef. And i want to upgrade my radiator anyways. I know there are many purple shafts between the 509 and 590, but I am talking current new shelf parts and I can only find that mancini racing puts out a 590 and a 509. Well they produce more but what else they produce is smaller than a 509.I've read the thread to this point and have some questions. What has you wanting a 440 powered car? Do you already have a 440 block/engine lined up? Are you willing to consider a different big block build to achieve the same 11 second build? Have you considered the need for a big block trans, torque convertor, radiator, headers, kick down linkage and other peripherals if you transition to a big block? And I'm sure you are aware there are a number of DC hyd & solid cams between the .509 and .590? I applaud your recognition of the importance for not hurting the 340 block if it is original to the car. A second engine does seem like the best plan to spare the original 340 and to build the 2nd engine as your time and money allows. Finally, to your original interest in the DC 'formulas', yes they are an older technology back when Chrysler was supporting race programs but are a good boilerplate/starting point to build your car into what you envision.
Eh i have mandrel bent 2.5" to the back, and will install cutouts and probably move to a 3" system. It'll be as close to open headers as I can get to without being pulled over. Also cant let those machine gun tips go to wasteThe old recipes are nice for a drag car (I think they assume open headers?), and really look at the required converter, gear, tire, chassis parts of the "recipes".
Sounds like a great deal on a 440. Your going to need some deals and luck to fit a tight budget. We still run 2295 pistons. Starting out with stock 906s and solid cam we ran a 11.6 with those pistons. 10s came later. I do still have a soft spot for MP stuff, its what we ran years ago. But, IMHO there are better options now..that cost less.Okay, what has me wanting a 440 powered car? Well, I had a original post, one of my first where I asked what can I expect out of my car, and a lot of people told me GO BIG BLOCK, as my car is heavy even with a small block. My top end and water pump housing and radiator are all aluminum, and im still at 3800 with me in it. Well, I got that 383 in the other thread, and a lot of people said go 440, as i could do everything to a 383 to a 440 and get more for the same price. Well I was kinda adamant on sticking with what I had, up until that block turned out to be terrible. Terrible pitting. I don't have a 440 machined block with a good rotating assembly lined up, but I'm talking to a guy right now who's old, and is selling all of his stuff so I can get a short block for a 1000(machined 76 440 block, forged crank, resized rods with good bolts, and trw domes). I have a 4 speed and a mcleod street extreme clutch and flywheel already, so from small to big i just need the bellhousing, which I was always thinking of going to a SFI one anyways at the rpm I turn, I dont want to have my legs turn into ground beef. And i want to upgrade my radiator anyways. I know there are many purple shafts between the 509 and 590, but I am talking current new shelf parts and I can only find that mancini racing puts out a 590 and a 509. Well they produce more but what else they produce is smaller than a 509.
Yeah, it really is. Thats why im on it. With deals and luck, i have 2 things in my favor. First is I'm 17, I think that has some play in negotiating price, especially with this old stuff where people "feel my first world struggle" I guess. Second is these people I talk to are old old, so not like they're gonna use it.Sounds like a great deal on a 440. Your going to need some deals and luck to fit a tight budget. We still run 2295 pistons. Starting out with stock 906s and solid cam we ran a 11.6 with those pistons. 10s came later. I do still have a soft spot for MP stuff, its what we ran years ago. But, IMHO there are better options now..that cost less.
