Power Steering Pump Cooler
I had heard that someone has started to reproduce the power steering pump coolers for the power steering pumps can anyone advise who does that? Thanks
Mancini Racing has new, correct reproduction Saginaw power steering coolers advertised on their website:
MRE - Power Steering Oil Cooler - Saginaw
Fits: 1969-71 273-440
NON-Date Coded
New correct reproduction Saginaw power steering oil cooler. Chrysler part number 2891162. Fits 1969-71 273-440 (non-Hemi nor T/A & AAR). Seven date codes available.
Special date codes available (special orders only).
Correct date coded hose and correct clamps included.
I have a cooler on a hemi with a Saginaw pump, post #27, that was originally on a 383.
View attachment 1863496View attachment 1863497
NON-Date Coded
View attachment 1863498View attachment 1863499View attachment 1863500
Just got this about a hour ago... $95.. going to mount it on the inside of the drivers frame rail (if i have room.. thing is 17" long.. and i'm at work so i can't check) :(
well.. pewp.. that's just a bit too large... gonna hunt for something a little smaller :(
I have a friend that added this cooler (Dorman 918-319 Power Steering Oil Cooler) to his 1970 RR with a 440 and 4.10 gears. He made a bracket so it would attach to the PS pump. He paid around $40 for it
Thanks gonna look at that... should be easy enough
I was thinking about getting one of these cheap coolers since they have brackets that can be modified, and it looks like the tubes are soldered, so they can be altered to fit, too, but I chickened out.
YES !
I am happy that vendors go to the trouble to make OEM type parts but four hundred bucks is stupid money.
When someone else makes a part costing one tenth the $400, it really drives home how stupid it is to spend the big money unless you’re driving a correct restoration.
Hey….I’m not against spending money on something that I want. I bought one of those lightweight lithium car batteries that cost about three times what a regular battery does.
My problem with the Glen Ray unit is that it provides no mechanical advantage over a similar part that is a fraction of the price. This battery spins the engine over faster than ever and weighs 33 lbs less than a regular battery.
YES !
Can't beat the price of one from a salvage yard as you stated in your CHEAP thread:
Post in thread 'CHEAP Power steering cooler options' CHEAP Power steering cooler options
Oh, piss off, Glen Ray.
FOUR hundred dollars? Really?
Now you are pissing me off. Have you done business with Bob at Glen Ray? Have you ever restored a car worthy of their work? He is a top notch guy and GR is a top notch company. He is retiring and someone bought him out. Huge shoes to fill. I would estimate 90+% of the high end restored Mopars in the works have Glen Ray radiators in them. PISS OFF!
I have never questioned the quality of their products, just the pricing.
I ended up with the Dorman 918-319 mentioned above, and hid it under the battery box, still gets plenty of air. Drops temp 10-15 degrees which doesn't sound like much but going from 180-165 was worth it..
