I moved on to the front end, since that is going to take some time to get done. It's pretty hot in the shop but I've got lots of fans. I got the drum off, loosened the castlenuts on the upper and lower ball joints enough that I could separate them. I swung a couple times and both came loose. I took the nuts and bolts out holding the lower ball joint onto the spindle and set it all aside. I removed the torsion bar clip with my fingers and then removed the lower control arm nut and washer. I used my nifty new tool and a good sized hammer and the bar slid right out. I slid the lower ca out as well. The bushing was shot as I expected. The lower ball joint was tight but the upper was loose and needed replaced too. I used my ball joint socket and unscrewed it from the upper ca. I had to use the blaster 5000 impact a buddy let me use and it got it broke loose. It laughed at my mac 1/2" impact. Lol. That's it so far.
