Ceedawg
Water won’t run onto your carpet and floor.How important is putting this plastic back?
It won’t if I add the plastic?Water won’t run onto your carpet and floor.
Very, unless you don't care if your door panels get wet and rot. Now if the car rarely sees rain... not overly important.How important is putting this plastic back?
I would only end up driving in the rain if I was caught in it. I do keep it garaged but it is humid here in Houston and I assume that would cause moister build up. Not entirely clear on the condensation science.Very, unless you don't care if your door panels get wet and rot. Now if the car rarely sees rain... not overly important.
Does your door panel hang over the carpet? Water will siphon down behind the panel onto the carpet. It’s a real simple thing to install for piece of mind.I would only end up driving in the rain if I was caught in it. I do keep it garaged but it is humid here in Houston and I assume that would cause moister build up. Not entirely clear on the condensation science.
I would say important. Keeps moisture from getting to the door panel and warping/damaging it.How important is putting this plastic back?
What about washing your car?I would only end up driving in the rain if I was caught in it.
Maybe planning to dry clean it?What about washing your car?
it is important for a few reasons.How important is putting this plastic back?
2.) I am an OEM type of guy with all my cars. So i want to replicate the exact factory look with all my restorations.How important is putting this plastic back?
Ok thanks. All. I was just being lazy because I have been putting so much time energy and money in this thing. Will go ahead and do it while the door panels are off. Should I do behind the passenger rear panels too?Keeps drafts away too
yupOk thanks. All. I was just being lazy because I have been putting so much time energy and money in this thing. Will go ahead and do it while the door panels are off. Should I do behind the passenger rear panels too?
