That all depends if you have learned your lesson?So Mods, did I give myself a long enough time out?
And when you hit the ground, you're trespassing.Don’t forget, if you fall you’re fired before you hit the ground.
Wouldn't that mean tails is more likely?
Lands in your catching hand as heads down, but is displayed as heads up as your hand rotates over to your opposite arm.Wouldn't that mean tails is more likely?
