That is how I do it..Nobody knows how to heel and toe? Right heel on the brake and toe on the throttle.....let up on the clutch a bit and little bit of pressure on the throttle and go. Road racers learn it early on and it works for the hilly roads too. I like the line lock and the solenoid release idea too.
There is a switch on the drivers side mid case that's for the reverse lights...I just finished the install of a used but new to me TKO 5 speed. (I have added the carpet since this photo was taken.)
Thank you to all that made this post so informative.
i can honestly say that his was by far the best upgrade i have done to this car. The car is way more responsive and fun to drive. I would have a hard time even considering an automatic in any of my projects in the future.
My apologies if this has already been talked about in a prior post. but i am having two minor issues.
1. the speedometer cable is leaking through the cable (not from the outside diameter of the aluminum adapter) and dripping on my headers and that's super annoying. i am assuming the o-ring seal is bad. if any of you have replaced the cable did you buy a new one from silver sport? or another company that has a better seal?
2. reverse lights. my car was a column shift automatic. what did you guys do the hook the reverse lights to the new transmission?
Thank for any and all information
I got my cable from SST. No leaks after about 18 months.1. the speedometer cable is leaking through the cable (not from the outside diameter of the aluminum adapter) and dripping on my headers and that's super annoying. i am assuming the o-ring seal is bad. if any of you have replaced the cable did you buy a new one from silver sport? or another company that has a better seal?
I agree.Never did like that neutral switch on a stick....heck, really liked not having it on my automatics too!![]()
Thing is....I've pulled engines apart that had been static for years and the bearings weren't dry. Surprised me the first time I pulled one apart that had been sitting for a very long time. How long does it take for 'all' the oil to drain off of a bearing? It doesn't happen over night nor does it happen after weeks or months.I agree.
I thought about what was happening. You are pushing the clutch to disengage it with the engine off. All that force is pushing the crank forward and the thrust bearing is taking the load - DRY. That's fine until you go to start the engine and you have a dry thrust bearing against the crank while you are starting.
Nope. I disengaged mine. I don't want that extra wear.
True - I used the wrong word. I should have said there is no supply of oil to the bearing from the oil pump, so what oil is there has no pressure behind it and little ability to keep the two from touching.Thing is....I've pulled engines apart that had been static for years and the bearings weren't dry. Surprised me the first time I pulled one apart that had been sitting for a very long time. How long does it take for 'all' the oil to drain off of a bearing? It doesn't happen over night nor does it happen after weeks or months.
Accept this is a neutral switch... Not a clutch switch.. So the clutch doesn't need to be depressed..I agree.
So you always start in neutral?I agree.
I do when driving a manual.So you always start in neutral?
