 - 10:29 AM
 - Dec 25, 2011
 - White Cloud, MI
Thanks for your help here.
I would love to know what difference in sound it would make if your system was set up in the reverse order, if any.How about a long a$$ glasspack in front of the biggest triple pass that will fit in the muffler area? I've got a 5x12x24 Flowmaster under my 62, but it's still a long ways from what I'd consider "quiet".
That's not my system, and none of mine are "quiet".I would love to know what difference in sound it would make if your system was set up in the reverse order, if any.
I hear you on the difficulties of my suggestion (pun intended), but it would have been a worthy and informative Engine Master's comparison IMOThat's not my system, and none of mine are "quiet".
It's just a packaging suggestion whereby a long glasspack can most likely easier fit, easier than after the muffler and tailpipe over the rear. Not a lot of room b3tween the gastank and springs for a long glasspack.
(My three hiperformance systems use 1. 70 series huge flowmasters, 3.5 in/out, full length tailpipes. 2. Hooker aero's, 3.5 in/out and turndowns 3. Magnaflow 3" in/out 24"case, turnouts in front of tires. #3 is quietest of the bunch)
This doesn't count the 3" truck Flowmaster on my dually, of the 4" one on my diesel. (Both singles, both quiet!)
It has been done the other way, and I suspect the Imperials were the way you mention mainly because that was the easiest solution for OEM space wise as others have noted. My goal would be the best configuration, and what that is has yet to be proven. Adding a third would likely get you close.Some Imperials have small mufflers/resonators ahead of the regular muffler and Imperials have 440's and are very quiet. I took note of that and put 12" glass packs in front of the turbo mufflers in my '70 Roadrunner. I like the way it sounds now, but if I ever want it more quiet, I can still put resonators on the tailpipes too.
.....and eventually the quiet wasn't foolin anybody.Back in the day the Imperial mufflers were the sleepers choice... Originally Imperials used single exhaust... So the single muffler supported a 440... Very quiet stock.. Use two and they would easily support big horsepower..
The picture above of Jimmy Addison's "Silver Bullet" is a modern interpretation of what was originally (back in the 60's) four Imperial mufflers....
Jimmy's Bullet allegedly had four Cadillac mufflers. Imperial mufflers I suspect would do the same job.Back in the day the Imperial mufflers were the sleepers choice... Originally Imperials used single exhaust... So the single muffler supported a 440... Very quiet stock.. Use two and they would easily support big horsepower..
