1974 Satellite SAME FRONT AND REAR SUSPENSION AS 66-70
FLY 9999
2:52 AM
East Coast
Before I drive 400 miles to look at a '74 satellite, can some one tell me about the front and rear suspension. I have many parts for B body from 66-70. The '74, that I want to check out, seems to be missing parts from the front and rear suspension and not interested in another big project. Been speaking to deceased owners wife and she has very little info on the cars. Could not get pics. My knowledge ends at 1970. Thought that Chrysler started making changes around 1973 to the suspension. Any help is greatly appreciated. Thanks
The front suspension is still torsion bars but the k member is vastly different, the upper and lower control arms are different, steering linkage is too. No sway bar will fit except for the 73 and newer models. Steering box is large sector too.
Rear suspension is still leaf springs but now the attachment points at the axle are cushioned in rubber. You can modify a 71-72 axle to fit but the 66-70 axles are too narrow.
The short answer to your question is…
No.
73 and later are completely different. Isolated front and rear suspension. Everything changed.
Isnt the rear a pretty simple, and very common change back to the earlier style tho?
I have no idea about differences in the front...
I have never done it. I know the axle isolators are huge with a big rubber isolater surounding the springs. The axle perch might be the same as earlier years. The axle dimensions are different among the years, perch width and hub to hub. The front spring eye is much larger with a big isolator in it. Swapping back can be done, easily is the question.
Is the front end more like the 76-89 F and M body?
No, it's just a more rubber isolated version of the old ones. The F bodies are " bent bar cars".
Calvert Racing makes a split leaf for the the '74. No stipulations at all.
For the rear you can change everything to the 72 and older rear set up. front spring hangers, spring plates, shocks, and leaf springs. This will allow you to ditch the rubber isolation on the axle. You will need to add a bushing or washer to the spring perch for the smalled center bolt on the springs. The rear shocks are different, using 72 and older spring plates will allow you to use the earlier style shocks. You will have to do something to the rear sway bar mount, either hemove it (what I did) or build a mount to the axle.
If you swap in an earlier axle, pre 1970 it really helps with tire clearance.
On the front the thing to look at is the K member where the rubber bushing clamp it. This is a very rust prone area, it may need some repair.
The rubber bushings can deteriorate and allow the K-member to move around. The best plan is to replace the K member bushings with solid bushings either aluminum or cast iron. The FJM cars use the same iso bushings as the 73-79 b bodies.
The shock are quite a bit shorter for the front and selection is poor. This k-member uses the superior spool mounts.
There are big and small block k-members, so if your swapping between the two you need to deal with that. You can stick the wrong engine on a K-member, but it will not be in the factory position. If your handy with a welder you can make it work.
What rear axle does the OP's car have?
A complete spring and axle package form 71/72 will bolt on to a 73/74 (and later) car.
A 71/72 axle can be made to work with some modifications to the perch holes.
E body axles are almost the same length and technically do work.
Almost all E body cars seem to have gotten an 8 3/4 axle, so there's another "package" swap from any 70-74 E body.
I don't see it mentioned that 73 and up T bars are longer than 66-72, so that's a "no".
Upper control arms are quite different as the alignment changed from cams to a sliding UCA mount point.
Steering boxes do interchange, but be aware of the pittman arm mount style.
In fact, M body cars almost all got a box similar to a "police" box.
