More pics and dimensions needed '70 cowl and firewall.
torredcuda
3:21 PM
New Hampshire
Need two things- first is dimensions for holes for relay on firewall as I neglected to get them before doing some repair work in that area. Second is pics of cowl contour as I know mine is caved in but not sure how much - is it almost flat or is there a curve to it looking from the sides?
The Picture of where the dent is pushed into the front of the cowl is to be flat with the bottom edge to have a rounded edge to it.
I don't see why a previous owner would of dented it in for. That IDK.
Thanks, it looks like it has a slight bow but anywhere near what mine has - kind of what I suspected. I guess I`ll pull out the stud gun and get to work on it. Now I just need the dimensions for the relay holes.
From the ridge/bend line on the left and down from the the hole/dimple just above the top bolt and also the distance down to the second bolt.
Ok. I’ll go out to the shop in a little while and see what I can come up with.
