I just cannot figure out this tach issue
DynaBro
9:33 PM
Prescott, WI
Running an MSD 6A with tach adapter. It's wired up solid. Purple to the tach, white to grey. The tach is functional. The issue is it only works when it feels like it, which is just about 1/4 of the time. No rhyme or reason to why it does or does not work and when. I don't understand what's happening. I've gone over every connection and ground. It's all good. Could the old adapter just be shot?
One thing I believe may be incorrect is the gray wire off the tach is connected to the purple wire from the MSD and the dark blue I have no idea where it is going. I think this is backwards?
I don't have one. Or any friends who might.
I am going to test the purple wire coming from the adapter with a multimeter. If that is sending the signal then I might need a new one. Or preferably someone on here who rebuilds tachs.
Yes factory and I aim to keep it that way. The adapter is sending a signal so it's the tach that's bad. Anyone rebuild them for an affordable price? Or is there a guide on how to open it up and troubleshoot it myself?
I'm not a fan of the adapter. For factory tach I like to upgrade to the rt-eng circuit board and it requires no adapters or filters. I can send you a link to video on how I did this myself.
I'd be happy to bench test your tach and even upgrade it for you, but be aware your problem could be a sticky movement that requires a rebuild. Some old time speedo shops still rebuild tach movements.
