Coolant temp sender ohm range
dan juhasz
11:31 PM
Whiting NJ
As far as I know the range for the coolant temp sender for a 69 Charger is 10 to 73. 73 being cold and 10 bring 250 degrees. I’ve bought numerous ones and none fall into those specs and of course the gauge either never comes off cold or hovers at 250 on the gauge. Does anyone sell a proper sender?
Sender at 68f room temp should read in the ball park of 360 ohms. 73 would be bottom of the actual gauge scale and 10 at full gauge.
isn’t 73 and 10 the range in ohms of the sender itself ? Where does 360 ohms fit in, I’m not following?
Here is some notes I have from when I calibrated my 1969 Rally dash:
At 120 degrees water temp (first mark on gauge), the sending unit (unloaded, connected to DMM) read 84.3 Ohms.
To get the same first mark position on the gauge with a 5-volt power supply took 62 Ohms of resistance and drew 62.1 mA of current.
At 150 degrees water temp (about 1/2 way between first mark and second mark) the sender showed 49.5 Ohms unloaded.
To get same position with 5v took 33 Ohms and current was 98.8 mA.
At 170 (second mark on gauge) sender unloaded was 37.5 Ohms
Loaded @ 5 volts took 22 Ohms and 119.7 mA
At 180 (needle straight up) 30.4 Ohms unloaded sender reading.
Loaded @ 5 volts 20 Ohms and 130.0 mA
I could not check sender resistance above boiling point (not pressurized when testing)
The next high temp mark, I think might be about 225-230? loaded @ 5 volts took 13 Ohms and 160 mA
Full scale (I think 240?) took 12 Ohms and 163 mA
Note that 5 volts was used for the Instrument Voltage Regulator (IVR) because I converted the factory one to solid state.
I bought the gauge style but I cannot remember the part number from Year One.
Works correctly.
Use sealer not thread tape.
The values in Red diamonds on the graph are extrapolated based on the curve I don't have a way to get the water above 210 deg
The Red Squares are the gauge readings 0 = cold, 25 = 1/4 scale, 50= 1/2 scale etc
My thermostat is 180 deg and my gauge sits at between 1/4 and 1/2, so in the 190 to 215 deg range
When I was checking the sending unit unloaded, I just had it in a Pyrex container on the stove with a digital thermometer. Because I didn't have a way to stabilize the temp the thermometer likely responded quicker than the bulkier factory sending unit, so the factory sending unit seems to respond slower to the actual temp resulting in higher readings the way I tested it. Testing oil pressure was easier, just used compressed air and a regulator to set different pressures.
Fuel gauge measured 73 Ohms Empty (lower stop), 9.6 Ohms Full (upper stop), and about 31 Ohms 1/2 way between the stops.
For the calibration @ 5 Volts, 51 Ohms seemed to move the needle to the Empty mark, 33 Ohms to 1/4 mark, 20 Ohms to 1/2 mark, 15 Ohms to 3/4 mark, and 10 Ohms to the full mark.
Oil pressure was like 51 to 43 Ohms just to read about 0 PSI, 15 PSI = 30 Ohms, 20 PSI = 28 ohms (two 56 Ohm resistors in parallel), 40 PSI = 20 Ohm, 60 PSI = 16 Ohm, 80 PSI = 9.79 Ohm (10-ohm in parallel with 470-ohm).
fuel gauge does not sit 1/2 way between the stops at 1/2 a tank due to the shape of the tank. If the tank was a perfect rectangle then it would be more likely to be that way depending on where the sender was mounted on the tank.
If you really want to know put the sender in the tank and have the car on flat ground. empty the tank completely then add 1 gallon of fuel and jostle the car. measure the resistance rinse and repeat till the tank is full. Assuming an 18 gallon tank at 9 gallons you should read about 23 ohms
Unless you have a 5V solid-state IVR the voltage to the gauge will make a difference on the gauge readings, as will the wire and resistance (mounted in the car) bulkhead connector terminals etc.
20psi at 28 ohms should have the gauge at about 1/2 scale
This is what I got with various A Body senders and for the gauge reading (Red Triangles) I used several 100W 10 ohm and 1 ohm resisters in series till the gauge read E, 1/4, 1/2, 3/4 F in the car with the cars IVR and the cars wiring.
Great videos that explain how out gauges work
Bench testing I have done on water temp sender is as Dads Bee mentioned. I tested three senders and at around 70 degrees F, they all tested between 250-260 ohms
Bench testing I have done on water temp sender is as Dads Bee mentioned. I tested three senders and at around 70 degrees F, they all tested between 350-360 ohms
Yep that's in the range I get too
The sender is a variable resister and has a very wide range that it can measure. Our gauges are only interested in the (roughly) 100 to 250 part of the range
So the sender that can read the interesting part of the range and can also read the other parts of the range BUT our gauges cannot.
Here is the curve that the sender CAN provide
Here is the PART of the senders range that the gauge CAN display
The gauge can only display this part of the entire curve
so when you measure the sender at room temperature it will read in the 300 ohms range till you heat it up to about the 135deg range, then it will be in the 73-10 range of its curve.
I bought a total of 5 senders before I came across one that measured around 400 ohms in 85 degree ambient temperature. That sender works and is accurate when checking with my thermal temp gun. It’s all about crap aftermarket parts nowadays. All the other senders measured between 120 to 200 ohms at the same ambient temperature. Those all showed between 230 and 250 degrees at idle with the true temp was about 175/180.
Often times the parts house will supply you with the wrong sender. It happened to me last year. In the picture, the sender on the left is new but bench tested at 500 ohms at room temp. (70F) The center one and the one on the right both read 352 and 360 respectively. I'm not sure what the part number is for the one on the left. It looks similar but has more threads and is not correct for a Mopar. The one on the right is a Standard TS-17.
I have a collection of ts17 and the economy ts17t. It’s like buying a moog lower control arm bushing, all wrong and unusable.
Ts17 or the T model is correct according to application but the quality control is out the window so you never know if it will work accurately or not
Again, if you want correct... post a WTBuy for an OE sender out of someone's old pump.
Yep I replaced IT with supposed to be correct for 69 440 car, does ok but inevitably hits 250. NO way hoses stay on at 250 I’d imagine. They’re ALL unknown ranges/Tested. BUT If I connect the idiot needle? It’ll read normal. Christ!
So I did browse SUMMIT looking to replace my latest Water Temp unit (sport Comp), I never knew Auto-Meter electrical guages CAME WITH their own sending unit. And just happened to have a new in box 2-5/8” water Temp guage and its sender was in the box. It’s 05:30 a.m. have the latest sending unit IN the water pump. I did check it with a DVOM ohm meter first, (1.7 ohms at 64 degrees in the garage), I don’t hate my neighbors THAT BAD just yet to fire the ol A12 up, YET. But will do so and report back. I had just replaced the 4th one with one from a VERY trusted E-Bay seller and it went to 250 yesterday. About sick of it!
Funny I decided to just Hook up the Factory Lead out of the engine harness yesterday to see what happened, and the damn DASH guage started working! It read near normal while the Auto-Meter pegged at 250 lol..
