1969 Charger 500 Radiator
Stucat
5:26 PM
Good morning. I have a 69 Charger 500. Purchased it like 20 years ago. Just a shell,yes , rear window plug, no drive train, doors ,hood ect. Question is the radiator opening is 22 1/2"? I thought all 440 charger 500 got the big 26" radiator?
Usually a 26” was for a performance axle package, a/c or a max cool package. If your core support still has the numbers stamped in or your fender tag is stamped for then you will know for sure.
Road runner here and axel package also called for bigger radiators in some applications. Stucat what axel and gear may I ask? Think automatic with 8 3/4
Auto or 4 speed car?
Most all did get the 26-incher, but yes, a 69 Charger 500 with limited options could come with a 22" radiator. I have only seen a couple, and they were 440 cars with almost no options, or as in the case of one of them..... ZERO options except the code for Charger 500.
Might have been a clone car maybe?
440 cars with an automatic came standard with the 8 3/4 rear, but all A12 cars came with the max cooling 26”radiator and the 4:10 Dana 60 regardless of transmission choice.
Yup... It was the axle not the trans that triggered max cooling...
3.23 or less gear without towing without A/C without HD/Max Cooling got a 22" radiator
Maybe a 70 then?
The A12 was 1969 1/2 year only option. But in 1970, yes, it was entirely possible to have a 6 pack or 6BBL car with an automatic and a 22” radiator.
Ok that’s where I musta seen it then. Thought it strange to have a 22 behind a 6pk
