Paul_G
- 5:55 PM
- Dec 24, 2013
- Surprise, Arizona
My 505 is toast. 2 broke pistons and the rest scored. How did it happen? I dont know yet. It denotated horribly. so what can cause that? Too much timing? Running lean? Failing fuel pump, clogged carb? Bad gas?
This engine has a 440 Source 440-512-5060 kit in it. PP240 heads. That should put it around 10.6 compression. That should have been fine. It was a beast, got absolutey no traction. On borrowed slicks it spun through first gear with anything more than 1/2 peddle.
The plugs were changed every year. No signs of detonation. Timing was held around 28° for street driving. The AFR's at cruise were around 14, WOT in the low 12's. On the track with Race Gas additive and 91 octane, I would bump the timing to 32°. Even with my poor driving skills (4speed) it still ran in the 12's.
I am putting it back together with the 5074 pistons from 440Source. Compression should now be in the high 9's. Much better on the street in 110° heat with the AC blowing cold. That engine never ran hot. In the summer heat the temps stayed under 200°
