themechanic
Oklahoma is OK
- 12:19 AM
- Nov 11, 2012
- Moore, Oklahoma
1969 Coronet R/T. Factory AC car.
Classic Auto Air AC system.
Factory 054 radiator with a new 4 row copper core.
New 16lb radiator cap.
Factory 7-blade fan.
Factory shroud.
New Hayden short fan clutch
Green anti-freeze 50/50 mix.
New heater core.
FlowKooler water pump and 180° thermostat tested before installing.
Factory AC crank and water pump pulleys.
New hoses with spring in bottom hose.
New belts.
Penn Grade 30 weight break-in oil.
Engine has about 100 miles on it since a mild rebuild with a roller cam.
Starts, runs and drives perfectly.
Timing is 18 degrees base and 34 total.
Factory radiator, heater core and engine were all flushed out. (Some unknown person for unknown reasons put radiator stop leak in the cooling system. Trying to reach the shop for days but no answer. )
The car has a factory temperature gauge and an aftermarket electric gauge. The factory gauge stays about the middle. Running 200°F at a stoplight.
190°F on the highway with AC on.
Laser temp measurement in driveway was 215°F on the thermostat housing and around 200°F on both the upper and lower radiator hoses.
Just a degree or two difference between top and bottom hose.
Ambient is 92°F. Humidity is 37% and the heat index is 95°F.
Factory shroud.
New heater core.
New belts.
