Original Cast Dual Point Distributor or Reproduction?
DMateya
5:26 AM
Pittsburgh, PA
Hello,
Any opinions on if I should buy and restore an original cast dual point distributor or get a reproduction that looks original? Does anybody make a kit to modernize the cast distributor?
My goal is to keep my car original but if reproduction parts that look original are needed then that is ok.
Thanks,
Drew
Does modernize mean second rate shines e parts?
I like the originals with points as designed, as they are a very high quality distributor.
How many miles will you drive the car?
My first call would be to Halifaxhops who is a member here. He may actually have exactly what you are looking for. If not, he may be able to make yours everything it can be, or offer an sensible alternative.
@HALIFAXHOPS
To give some background I have a 1970 RR with a 440+6. Originally it was a 383. Otherwise originally the car had a 4-speed, front split bench, air grabber hood, etc. I want to make the car as original as possible and plan to drive the car. I am looking to keep the car for my family and am not interested in selling.
Nonone makes a cast iron repop that I have seen.
Hello,
Thanks,
Drew
Hops actually has a big block dual point listed right now, I think it’s listed here!
Just saw the tag. Lots of ways to say modernize. Yours should be a Prestolite cast iron dual point, not the one in the add, that one is super rare. I sent you my # way easier to talk if you want. As far as I know no repop dual points around now the aluminum housing there are a few but I personally do not like them and they will not have any part number on them either if that matters.
Hello,
Thanks,
Drew
If you mean to make it electronic instead of points, yes, Pertronics makes a kit for the dual point that keeps the original look on the outside. Since you replaced the 383 with a 440+6, original has long since left the building.
What distributor do you have now? Pics?
You car originally is a 383 4spd that now has a 440-6 4spd.
Are you trying to make it look 100% original? What does the engine compartment look like now.
A $1800 OE restored distributor might be a fart in the wind to all of what else you have going on.
