BearDodge67
Nowadays new cars come with no spare, just 3yrs of "roadside assistance" or a can of fix a flat.
what’s AAA going to do other than have to haul the car?
Yeah, I've had to use them a few times. In the case of a trashed tire that can't be repaired, a spare sounds nice to have to keep going with out a car carrier ride..Yep, exactly. First 100 miles free. Usually $6/mile after that.
I never needed one but I do have the factory bumper jacks in the trunk. I wouldn't mung up a $500 chrome bumper for a flat tire though. Check your collector car insurance, You may have towing coverage.
I always wanted an aluminum racing jack but I can see the scissor jacks would work well. They start jacking down low and operate easily. You could fashion a driver for a cordless drill and make quick work of jacking up a corner to change out a tire. Make sure your spare is aired up and worthy of the task and that you have the proper wrench and lug nuts for the stock wheel.
Spare tires should be very close to the same diameter as your rear tires. Most of our cars have Sure Grips and different diameter tires don't play well with the SG units.
Bolt pattern ?I found a late model temporary spare which is the same diameter (27 inches) as my normal tires. It even fits in the factory trunk well.
Same here!I keep a small bottle jack and a piece of three quarter plywood to give it a wider base in a duffel bag
4 1/2 inch. Out of a Ford Edge. I had to open up the center hole just a bit.Bolt pattern ?
For about 20 years I commuted 220 to 150 miles a day, most of that was the larger commute, I think I had a tire go out on the road once in that time and needed my spare.Certainly.
Was this an actual personal event, or a hypothetical?
In a million miles of driving cars on steel belted tires on public roadways I think I’ve experienced one flat tire (actually my wife) and zero tire failures.
Anything can happen. Weighing “anything” against preparation for “anything”, verses the likely hood of “anything” has put me in the place of doing less.
When I started in this hobby over 50 years ago, I carried half of every tool and spare part I had with me at all times. Broke down once and didn’t have what I needed. That day I swore I’d never pack that stuff again, and generally haven’t.
I have a small bag of about 30 hand tools I take to the track or long multi-day out-of-town trips.
I know I just jinxed myself.![]()
