10BTDC is the line AT the 10. Where is your’0’ TDC mark on balancer? I see a bunch of lines in your picture. You need to mark the TDC line on balancer with chalk or white grease pencil.
It's a bright white line under that black line and piece of tape at the very bottom. I placed some tape there with another line at 2.36 inches counterclockwise from the TDC mark to attempt total timing.
I did the math and verified it with Grok. At 3000RPM the 2.36 inches counterclockwise from the TDC mark should align with TDC.
If the idle speed is close to what it was set at the issue is inside the distributor. What this video for disassembly
