oldbee
10BTDC is the line AT the 10. Where is your’0’ TDC mark on balancer? I see a bunch of lines in your picture. You need to mark the TDC line on balancer with chalk or white grease pencil.
			It's a bright white line under that black line and piece of tape at the very bottom. I placed some tape there with another line at 2.36 inches counterclockwise from the TDC mark to attempt total timing.
I did the math and verified it with Grok. At 3000RPM the 2.36 inches counterclockwise from the TDC mark should align with TDC.
If the idle speed is close to what it was set at the issue is inside the distributor. What this video for disassembly
Fair. And there's none of that going on. In fact it runs pretty smoothly but nor correctly. New distributor arrived today so hopefully I can get that installed this weekend and narrow this down. MY friend has a brand new MSD 6AL I am hooping I can simply plug into my existing MSD harness and test that theory.Inconsistent triggering will cause rough running/backfires.
Swapping parts is one way to go about it, but really not a good way.Fair. And there's none of that going on. In fact it runs pretty smoothly but nor correctly. New distributor arrived today so hopefully I can get that installed this weekend and narrow this down. MY friend has a brand new MSD 6AL I am hooping I can simply plug into my existing MSD harness and test that theory.
You really need to ask yourself why that would affect timingThere has been a new discovery. The crank bolt is oversized. I don’t even know how big yet because the largest socket I have is 1 1/8. Guessing 1 1/4. Balancer is not oversized but it does have balancing holes along the edges.
If it has a stroker kit I didn’t know about, and the previous owner certainly didn’t know about, and it has a distributor for a 383, I think that’s pretty obvious. For reference this car barely shifted when I got it and the guy I got it from didn’t know anything or care. It was stored and neglected other than cosmetically. Every piece of the motor was leaking, both gas and oil. I am not even shocked if this ends up being the case.You really need to ask yourself why that would affect timing
No looks like some over sprayed paint over grime that simply fell off.Are those rust holes?
God no. The entire motor needs a serious power washing. Honestly I want to pull it and either replace it with a nice fresh one or if this turns out to be good news, clean up, do the necessary repairs, nice and repaint.Are those rust holes?
