400/451 Stroker conversion question
TacticalDawson
New Member
10:42 PM
New Jersey
Hey all!
So im thinking of grabbing the stroker kit from 440source and im wondering what/if anything needs to be done to the front/rear suspension and transmission if we turn the 400 into the 451 and what advice you all might have when it comes to suspension work for the 451 if it needs to be done at all.
Hey all!
What did the car come with from the factory? 318 and 904?
Unibody cars can always benefit from stiffening the Body, frame connectors help.
Would also recommend replacing torsion bars and springs if they are old. Increase bar diameter and use HD rear springs with extra leaf on passenger side to help with increased torque.
Expect to pay for transmission that will hold to increased power. If rear axle is 7 1/4, will need to replace with 8 3/4 or Dana for increased torque or baby the car to not break rear end.
And don't forget to increase braking power to stop increased horsepower use and abuse.
Hey all!
If the car came with the 400, you dont need to do anything.
Brakes and suspension are common upgrades out of general principle, but not need.
It sure saves money if all you do is install a bigger, more powerful engine but you won't get the most out of it without upgrading other areas.
Brakes, man.
3 or more years ago, a video was making the rounds on the internet. A guy with a pro street 64 Mercury Comet was out on a drive with a guy that was interviewing him for a YouTube car related channel. The guy had undersized brakes for the power the engine was making. Unfortunately, he had a sticky throttle so he was riding the brake pedal..... that heated the brakes quickly. The idiot kept driving the car despite riding the brakes to keep the car from running away. He ended up ramming into some innocent motorist but somehow avoided killing anyone.
I am not a person obsessed with safety but I am aware of the need for brakes that match the increased power.
When I had my engine out in 2022, I upgraded the brakes. The car stops better now than it ever has.
That's a pretty extreme example. We're talking about a regular car
If it was an automatic, the only one fitted to the big block was a 727.
The LA series small blocks could have had a 904 or a 727.
I don't mean to come across as a worrier. I'm not one to recite the safety handbook but when it comes to doubling the power of a car, I like to make sure the car can respond well with it. I'm a big fan of improved handling and braking anyway but when the power levels are increased, those changes not only make the car easier to handle, it is a lot more fun too.
The classics can be made to stop and handle quite well. We get used to how our late model stuff drives and handles. We can make our classics so much better than they were when new.
Assuming the 400 you have is a weak-suck 7.5 to 1 engine, a 9.5 to 1, 451 kit will really wake it up. But I don't know if I'd bother if I couldn't afford a good set of aluminum heads to make the stroking worthwhile.
If you DO do the stroker, I would add a 2500-3000 converter, and a suregrip unit in the 8 3/4, if it doesn't have one.
Sway bars front and rear. Fresh pads and shoes, f and r. Unless the springs/t-bars are sagging, I wouldn't worry. Frankly, if you do the stroker with aluminum heads, headers, aluminum water pump, your front end might actually be lighter by a hundred pounds!
This.
However, A complete list of your cars current condition and what your planned upgrades will go a long way to getting the answers you want.
A side note, if your current 400 is external balance, and you get a kit from 440 source, make sure it's external balance also, or you will have to swap convertors
You wouldn't try to external balance an aftermarket forged Internally balanced rotating assembly.
If going with an all new stroker kit why only a 451 and not the 512 kit?
both kits are internal balance so need neutral balance converter and crank damper.
If not using a race oil pan, the reproduction 6 quart hemi oil pan fits nice about flush with the lower part of the k-member.
Depending on intake/carb/air filter hood clearance can be an issue.
Need good motor mounts and a way to limit engine twist like a torque strap or solid drivers mount.
With aftermarket intake/carb the accelerator cable and transmission kickdown are usually a problem. The aftermarket cable assemblies like the Lokar setup are a simple fix, but they don't have good instructions on how to trim the cables and setup the assemblies.
I have used Hooker 2" Super Comp headers and I don't recommend them as they don't fit good on the low deck. The smaller diameter tube hookers fit OK, but if you have the $$$, the TTIs are good. I hear the Dougs headers are good too, but haven't used them.
Suspension depends on application. If drag racing, get front drag shocks and factory torsen bars.
If street/handling get larger torsen bars (I like the old Mopar 0.96" street handling bars, most aftermarket are around 1")
Sway bars are nice on the street but need to be matched the the front and rear spring rates.
Rear springs and suspension for application. Stock springs and shocks will likely have axle wrap and poor traction.
I haven't done alot with my rear suspension usually just use heavy duty springs with clamped front segment and a pinion snubber. The calTracks are popular.
