- 2:13 PM
- Apr 13, 2012
- Granite Bay CA
New bulbs are in.
I often get the terms mixed up when identifying these headlights.
The H4 are dual filament. I thought I could just reach behind and replace the bulbs with the lenses in place.
No.
First, the high beam.
I thought I’d see an H1 on the face. I do see an HR.
Like a member mentioned, the ground wire goes to the housing. It was several years ago that I put these in so I did not remember.
Single spade does work. I’m surprised to see 55 watt. I thought these were 60.
The irregular shape ensures it is installed only one way.
The H4s high/low are next.
Looking at how the glass is, you can see the bottom 40% to half has subtle flutes. Above that the vertical flutes are more evident. This results in a light pattern that has a bit of a cutoff as seen in previous pictures.
Typical 3 prong arrangement.
Get your reading glasses for this one.
50 / 55 watt?
I thought these were 55/60.
No.
50 / 55 watt?
