Nismobishi
Hello,
I can not find a Carter 6903 pump in stock anywhere so I went with the Edelbrock 1723 which looks identical and has the same specs except that it is polished and has 3/8 NPT fittings instead of 1/4" NPT fittings.
I had to use a couple of adapters because I could not find the correct fittings that I needed and I was in a hurry to be able to move the car.
For inlet I have the 1/4" NPT barbed fitting adapted with a 1/4" NPT to 3/8" NPT adapter bushing.
For the outlet my fuel line is 5/16" inverted flare that already had an adapter to 1/4" NPT. On top of that I had to add a 1/4" NPT to 3/8" NPT adapter bushing.
So, long story short... 1 adapter on the inlet and 2 adapters on the outlet. All are sealed with Permatex thread sealant. No leaks at all and the car runs great.
On to the big question... Can I leave it like this or should I order the proper fittings so that there are no adapters being used in the long run?
