70runner
If you don't find an electrical gremlin, assuming mechanical fuel pump, check the fuel pump rod for wear. Daughter's 69 Charger (recently rebuilt 440) behaved pretty much as you described in OP. Checked electrical, stock points, et al., everything seemed fine. Would startup and run for awhile. Checked fuel flow, seemed OK. On a hunch, removed fuel pump and checked rod. Obvious wear. There was a bad aftermarket batch of these, suspect engine rebuilder installed one. Replaced with NOS rod, has run perfect for a year since.
