Is there an exhaust crossover port in the heads
Karl over on A Bodies just listed a pair . He's a great guy. By with confidence.I could use a lead on purchasing a set of stage III heads for my 1964 Max Wedge motor, also need the original intake. Anyone know of or have a set for sale?
no crossover port!Is there an exhaust crossover port in the heads
What intake is on there?? What kind of valley pan/ plate ?what engine is in this car? The block casting is 2406730-1, I pulled the valve covers last night and the casting numbers are 2406518-1. It has a single 4bbl carb, block and heads based of casting numbers = 426 Max Wedge, on the top right side of the block it's stamped 426. Is this a Max Wedge with the wrong intake?
I have no idea what the current manifold is, I'm going to pull it apart this weekend and try to identify. Block, heads and exhaust manifolds all indicate a Max Wedge, but this intake manifold has me questioning what motor I truly have. Were there options to put a single carb manifold on a max wedge motor?What intake is on there?? What kind of valley pan/ plate ?
Very limited.. and from the small bit we can see ,looksike a dual plane? There was a Nascar single 4 with built in plate. Or someone welded and enlarged th ports of a stock port.. or maybe an indy dual plane..I have no idea what the current manifold is, I'm going to pull it apart this weekend and try to identify. Block, heads and exhaust manifolds all indicate a Max Wedge, but this intake manifold has me questioning what motor I truly have. Were there options to put a single carb manifold on a max wedge motor?
will do, thanks for the reply.Very limited.. and from the small bit we can see ,looksike a dual plane? There was a Nascar single 4 with built in plate. Or someone welded and enlarged th ports of a stock port.. or maybe an indy dual plane..
The valley pan should tell us. Peel off the aircleaner and snap some pics!
